Old 01-31-2008   #3
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: Standalone ECU from Scratch
Originally Posted by Jungy View Post
Yeah msII works with the neon/420a code now there are guys on 2gnt.com that have been runing it for a little while now. Msextra.com is very useful there are alot of experienced ms tuners on there, there really wasnt anyone that had run e85 on the 420a when i started tuning and I got alot of help to start me off from the guys at diyautotune over on msextra.com. With mounting your ms in an old ecu case make sure there is no way the ms can make a ground loop, you arent even supposed to mount the ms case to metal. Sounds like a tough project with connecting the ms to the factory ecu plug but i know the ford, bmw, and miata guys have done it!
Just to clarify I am not going to use the old ECU case, I am just using the connectors to plug into the harness. I will solder wire from the old connectors to what the MegaSquirt plugs into. It should work out pretty well. I haven't figured out where to mount the ECU though... I need a place that I can hook up a serial connector.
What is the rest of your setup? Maft and an AFC can go a long way if setup right.
Well I know they can but I kind of wanted to go standalone instead of piggy back. I kind of wanted to get into real tuning with the ECU and make the most of my modifications. Plus I wanted to run the bigger injectors for maybe E-85 and take control of the timing. As you know piggy back systems don't have that possibility.
So it was between DSMlink, AEM, and Megasquirt. I am not saying that DSMlink and AEM aren't bad systems. It just seemed like Megasquirt seemed to be the ECU for me because you can build it from scratch and I love building thing from scratch. Plus the MSII system and processor has huge possibilities. Plus I can't beat the price so far...
I am really not that happy with the MAF-T. I think the old MAS did a better job of reading air. Especially in this cold weather I am finding out. I was going to switch to a 2g MAS and AFC but realized my goals are too large for that combo.
Modifications are pretty light right now
Before I did real big modifications to the car, I wanted to make sure this system will work with the car that I have. Kind of establish a base tune and then tune every modification from there.
The modifications are going to get big...
Remember a couple post ago
I found a 4g64 in an expo not that long ago.
