Re: 1g to 2g motor wire harness HELP
One triangle on the very end by itself is for the AC. The triangle next to a square a few inches from the end is crank/cam sensor as I said earlier, the triangle a few inches further back, near the center of the intake manifold is for the coil pack. Everything pretty much falls into place really, I was worried about it until I got the motor in and everything was really simple to figure out.
According to magnus writeup you should be using the 2g sensor for TPS, the 1g is different. Not sure if the other sensors matter much.
