04-18-2008
#2
Hates blue couplers.
Re: WTB: Chassis/Trans-block - Please!
Originally Posted by TkrPerformance
ok
just to make sure
you need all the 14mm head bolts for the tranny and the 12mm head bolt also
1.12mm 4.14mm (the 14mm, I have 2, for the top, but if you have all, I'll buy 'em.) (the 12mm, I don't know where that one go's, but I'll buy that too.)
next
the bolts that mount to the block or the ones that the upper mount that bolts to the engine. (I need the bolts that go through the bushing and "lock" the collars to the mount) I found all the bolts that hold the front/rear mounts to the block
last
do you need all 4 of the bolts for the mounts the go through
upper engine mount bolt with nut
lower tranny mount bolt with nut
front and rear roll stop mounts bolts and nuts
I'm not sure on the last.
I need the ones that hold the trans to the block, the ones that "lock" the collars to the mount, that go through the bushings, grade 8?)
And the bolts that hold the Mounts to the Chassis, 3 in the rear and then 1 in the front I believe. (just for front/rear mounts.)
And I need the 4 bolts that go through the wheel well that hold the trans mount to the chassis as well.)
I'm sorry, I suck at explaining
I would go to a hardware store, but everywhere within 12 miles has NOTHING, I checked. Shit, if you can buy them new, send me the bill.)
