Old 05-30-2008   #1
DSM_421
FS: 1991 Eagle Talon TSi AWD
This car has been my daily driver since about this time last year, It was stored all winter long and never saw salt.
I am the third owner of the car, the previous owner had owned it for 9 years, he also stored it during the winter time for the last 4-5 winters he owned the car.
Basically the reason I'm selling it is, I'm sick of my Dad and want to move out and need the money. I will be going to school full time in the fall as well as working full time. I really don't want his finacial support anymore which means this car obviously has to go.
5 Speed Manual Transmission
Body has 218,000 miles.
Motor has about 20,000 miles on it. (6 bolt)
Asking $5,000 firm
Tuned at DB Performance, made 282 awhp 255 awtq @ 20 PSI (Bad Gas, could use retune)
Head
HKS 264 Intake / 272 Exhaust Cams
Crower Springs
OEM Valves
OEM Retainers
Bronze Valve Guides
Ported Runners and Bowls
ARP Head Studs
Engine
PTE SCM50
Manual Boost Controller
Denso 660cc Fuel Injectors
Buschur Fuel Pressure Regulator w/ Gauge
1g Big Rods mated with 2g Pistons, 8:5:1 Compression Ratio (.5mm over)
Walbro 255 HP Fuel Pump
2g Ported Exhaust Manifold
2g Ported O2 Housing
Indy Race Core's - Race Core Front Mount Intercooler - Very Large
2.5" "Short Route" Intercooler Piping
2.5" Throttle Body Elbow
1g Throttle Body with removed Emissions
Greddy Blow Off Valve
2g MAS
90 Oil Cooler Housing
Setrab Oil Cooler
2.5" Downpipe
3" Test Pipe
3" Pressbent Catback
Fluidyne Aluminium Race Radiator
Forced Performance 4" Cold Air Intake with Recir.
Oil Catch Can
NEW NGK BPR7ES Spark Plugs (One Step Colder)
NEW Accel 8mm Spark Plug Wires
Electronics
Innovate LC-1 Wideband w/gauge
DSMLink on EPROM ECU
Greddy Peak/Hold Exhaust Gas Temperature Gauge
VDO Oil Pressure Gauge
Stewart Warner Boost Gauge
H4 Headlight Conversion
NEW Napa Battery, couple months old.
Clarion CD player, Sirus Radio Ready
Black Widow alarm system
Suspension/Drivetrain/Tires
ACT 2600 Clutch
4-Bolt Viscous Limited Slip Differential Rear End
Switchable JDM Galant VR-4 Tranny (Taller 1st and 5th Gear)
KYB AGX Adjustable Shocks
Eibach ProLine Springs
Energy Suspension Bushings, Except Subframe
ST Rear Swaybar
1g Big Brakes (2 Piston)
SS Brake Lines, All four corners
Whiteline Rear Camber Eccentric Bushings
80% tread left on tires
Also included but not installed
Almost New 2.5" to 3" Megan Racing Downpipe
Almost New 3" Megan Racing Test Pipe
Almost New 3" Megan Racing Catback w/ removable silencer
-Four NEW Vibrant gaskets needed for exhaust install, along with NEW bolts, nuts, and lock washers
NEW LIPP Cast o2 Housing
-Also comes with NEW gaskets needed for install
I will get pictures up tomorrow after I give it a good wash.
Please feel free to PM me with any questions, flakers and low ballers don't bother.
ID:	7449   Click image for larger version
ID:	7450   Click image for larger version
DSM_421 is offline
