Thread: New Welder...
Old 07-12-2008   #10
Re: New Welder...
Word up on the Non flux core welding, and just get like a Hobart Handler for a 110volt outlet, it will weld up what ever you have in mind out of mild steel or stainless (with the right wire and a little welding under your belt). Also for the Miller units they now have a spool gun setup for the smaller MIG welders for welding aluminum, but for this stick with TIG its much better to just pay someone who knows what they are doing.
Flux core welding, it just should not be done, unless you are welding with a lot of amps (over ~300amps, then dual shielding welding is required).
