Old 09-22-2008   #21
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Can't hold boost, did a boost leak test, check inside.
I know were running E85 so we can boost this high but what is the point? This turbo's peak efficiency range is like 27-28 MAX. After that it's pretty much just hot air blowing and your probably killing the life of the turbo. You can probably make more power with adding more timing and running the 26 to 28. Although I still spike to 27-28 and drop down to 24 by redline and wish I didn't there's really nothing you can do on the internal gate.
-1990 Mitsubishi Cyborg 4WD-
