Old 11-04-2008   #2
Re: Dataloger findings
Originally Posted by TsiEagleTalon92 View Post
Upon finally getting my PDA hooked up to an old enough computer I was able to check things out with my really poor running eclipse.
The only stored error I had was for my throttle position sensor. I don't know how just this could make my car run like junk all the time.
when I went into the data log section my throttle position was reading at 9-10 and underneath it read 9/ 11 so is this something normal? My air fuel ratio was 18 to 19 and again underneath those two numbers it gave me 18.XXX/19.XXX I am going out on a limb and thinking these are ranges to be in? What should my a/f read at idle?
Well on a wideband oxygen sensor you should be seeing around 14.7:1 afr to 15afr, thats what mitsubishi and most people usually shoot for.
A poorly functioning tps could be a huge deal on a vehicle. That is the source of your accel and decel fuel triggers. It seems that your throttle only shows 10% max? That would mean you have no accel fuel or decel fuel settings. The ecm is most likely in a limp home mode also due to the lack of a throttle signal.
