Old 12-04-2008   #11
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
Re: DEBATE: Plasma or LCD?
Originally Posted by TheBlizzard View Post
Plasma tv's are quite a bit different; but are commonly confused with LCD's, plasma's use electronically charged gas to display the image, the technology is very cool but there is a major draw back. From the time you power on a plasma it is not 100% anymore; slowly over time the gas will break down and the picture will not be as vibrant. Sure it might take a year or so of use to see a difference but it is definetly there. I think the image quality initially will be better with a plasma but it will slowly get worse. And if the screen is damaged at all you risk the chance of the gases leaking out and basically making the tv junk. To the best of my knowledge you cannot repair a plasma when it dies.
Plasmas do lose their brightness from initial start up. However they have a lifespan of 60,000 hours. That's at least 12 years at moderately high usage. The TV probably would be replaced by then.
I vote plasma. Primarily for the no loss in brightness when viewed from the sides.
