Old 12-22-2008   #11
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: Opinions on the Holset HX40 Turbo
Sorry for bringing back an old thread. I was browsing around this pretty nice forum and I couldn't help myself. Boy, for not knowing anything about Holsets, you guys have a lot of advice about the HX40.
10 points to clear the dust about the Holset:
1)Bullseye Power (BEP) doesn't make Holsets. They sell/sold them.
2)Brent Rau, the fastest 4g63 driver in the world, has a Borg-Warner turbo procured from Bullseye Power.
3)The gt35r is a ford turbo diesel upgrade. Curt Brown's Evo featured a gt37, another “diesel turbo”.
4)The hx40 pro in the .55a/r BEP turbine has put down over 650whp by an amateur tuner
5)Considering the hx40 pro has a 68lb/min choke flow (60% efficiency), it is apparent that the .55 a/r housing is NOT a restriction to the HX40. The bolt-on hx40 still spools FASTER than the lower flowing gt35r. This is a testimony to the HX40 turbine wheel or the BEP turbine housing. Take your pick.
6)The hx40 in the .55 a/r BEP housing spools to 20+ psi by 4100rpms on a 2.0L motor with 272-style cams. How much later spool is this versus the OP's 20g if it is a td06 20g?
7)The HX35 in the bolt-on housing on a 2.0L4g63 with stock exhaust manifold at 25psi has put out 494whp. Another DSM with stock intake and exhaust manifolds has gone 11.2@ 126mph with a nearly stock weight AWD. These hx35 compressor wheels have the 52lb/min compressor map. It is apparent that the .55 a/r housing is NOT a restriction to the 52lb/min HX35.
8)The hx35 in the .55 a/r BEP housing spools to 20+ psi by 3500rpms on a 2.0L motor with 272-style cams. How much faster spool is this versus the OP's 20g if it is ANY 20g variant.
9)The HX35 and HX40 cores are rebuildable. Garrett ballistic turbos are not. Holsets have been known to last literally over a million of miles under constant surge and rapidly changing flow demands.
10) How much did YOU pay for your turbo?
If some of you are trying to steer sales away from BEP, then you're going to have to talk negatively about some product other than a Holset. A crappy GARRETT v-trim turbo performing poorly in a 4g63 application has nothing to do with a Holset.
All the proof, experiences, and data can be found in the links within the first post of this thread (and in the rest of the thread of course). I am definitely not trying to be smug. I completely understand why one wouldn't recommend a turbocharger they know nothing about. So this is the only reason why I am posting this.
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
