Old 02-04-2009   #10
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: Clutch Low Engagement(yea, I know it's a DSM)
Originally Posted by joesushi View Post
Had this problem all the time and i always got it fixed. IF: There are no bubbles in the system. The pivot ball has been shimmed. the flywheel is stepped properly. And everything you can think of has been done then i would seriously recommend extending the threaded master cylinder rod. On all three of my 1g's, this fixed my problem. Cut about 1/4-3/8'' of the threaded end off and have about a 1/2'' of some other bolt with the same thread welded on. Then reinstall and you should have instant engagement at the top. You are welcome to see it working on my bro's talon anytime.
Yea, I ended up welding a nut on 4 years ago on my maroon 1g. It worked great.
'04 Honda Ricer: stock
