Old 10-30-2003   #11
I figured everybody knew what was on my car from the Featured Members post. :uh:
I have replaced the ignition transistor module.
I was having this problem before my car hit 29-30psi.
It still drives fine, no loosing coolant, no miss-fires under light boost.
The 2 plugs are dark from fuel, probably from miss-firing.
Originally posted by Nash@Oct 29 2003, 10:03 PM
http://www.dsmstyle.com/forum/index.php?showtopic=25
1ViciousGSX:ย* PLEASE, PLEASE, PLEASE, give us all the correct information about your car (year, engine, 5-speed or auto, current mods, turbo or non-turbo, etc.). This can only HELP YOU get the best answers to HELP YOU.
Not everyone knows what you have done to your car.
Modifications so far:
Engine ยท HKS 272/272 intake/exhaust cams - Fidanza Timing Gears - Balance shafts removed - Fluidyne radiator - FAL Twinline fans - (NOTE: I'm still running the stock 2g intake manifold, cylinder head, shortblock, and throttle body)
Fuel/Ignition ยท DSMLink v2 ECU Datalogger/Tuner Package (If you are not running one of these, you should be!!!) - MAFTranslator w/GM 3.5 LS1 mas - Apex-i S-AFC (only for display of rpm & tps) ยท DynoTune Digital O2 Meter - 750cc FIC Ball/Disc injectors ยท Upgraded fuel pump - Fuel pump re-wire w/10 gauge wire ยท MSD 8.5 spiral core wires - NGK BPR7EIX (Iridium) Plugs gapped at a tight .028
Turbo ยท VPE GT3056 TO4E B/B Turbo ยท Tial 40mm External Wastegate - VPE S/S O2 Housing Routed for External-Internal Dump - DN Performance Tubular S/S Manifold ยท HRC Upper/Lower Intercooler pipes ยท Dejon Tools intake pipe - K&N air filter - GReddy Type-S BOV ยท GReddy EGT ยท Autometer Phantom Boost Gauge ยท GReddy Profec-B Boost Controller ยท GReddy Turbo Timer ยท BIG GReddy 24R FMIC (upper part of bumper opening cut out behind upper black strip for improved air flow to FMIC) ยท Catch Can breather element
Suspension/Handling ยท Eibach Pro-kit 1.5" springs which have been cut to lower the car a total of 2 inches ยท KYB AGX 4-way adjustable shocks ยท Ingalls adjustable camber kits at all four wheels - Front/Back strut tower bars ยท 18x8 Rays Engineering/Volk Racing AV3 wheels ยท Nitto NT555 225/40ZR18 tires ยท Metal Master brake pads
Clutch ยท Clutch Masters 2500lb w/Ceramic 4-puck Sprung Hub Disc (custom kit good for 600+ HP) ยท Clutch Masters Billet Aluminum Flywheel w/Steel Face
Exhaust - RSR 3" downpipe ยท HRC 3" hi-flow cat ยท Apex N-1 3" cat-back exhaust
