Thread: Clutch Opinions
Old 05-04-2009   #15
Re: Clutch Opinions
The iron clutches are a bit tricky to drive on the street but if you get off it quickly you should have no welding problems. Unfortunately at the power level you are at, you will be pushing the limits on any single disc setup. You just don't have enough clutch diameter to harness the torque without having to give in pedal pressure (substantially) or longevity/driveability.
