Re: 1g hard to get in to gear when running
Try the clutch adjustment screw at the pedal? Turn the screw away from the pedal and see if it helps any, maybe the clutch isn't disengaging 100%. Though I'm not sure why this would just start happening.
Or have someone check to make sure the slave is moving in/out. Maybe it's the master or slave going bad.
