Old 05-29-2009   #1
Gravy
Who's this guy?
Re: Tunning question
I should have over a dozen logs, and i've tried looking for anything that changes, Hrz doesn't change any that i've seen, tps doesn't move, but when it goes over the oxygen sensors do register it. Twice in the past two days now i've got it to throw a CEL. However, when i go to pull it nothing is stored. I've even tried to read it when the light was on and still shows up nothing. Happens if i cruise for a long time at the 10.1:1 or around that area, so i assume it's giving me an Oxygen sensor code... but why it doesn't stay is beyond me.
Tonight i'll be going though the logs, i have everything logged as of right now, and am going to make sure nothing is changing when this happens, but i havn't seen anything yet. Someone said it could be the alternator, and i thought long and hard about it, but that's not coresponding, neither is any extra draw or anything else. When the alternator is on, i see about 13.8-14.1 volts, and when it's off it sees high 12's. However it doesn't corespond to the switching. I'm thinking of improving a few grounds and adding a few to the engine bay to rule out that as an issue, but i've got no reason to think that's a problem.
Still quick enough to keep away from a camaro with exauhst, so performance isn't affected at all. Just runs kinda rich, and ruins my gas millage.
May have found something, front 02 is cycling MUCH quicker than the rear, rear doesn't cycle often and when it does it's only for a short time. Doesn't seem to match the symptoms of the rich/lean problem much, but it looks to be a good place to start.
Last edited by Gravy; 05-29-2009 at 11:22 PM.. Reason: Found something hidden in the logs
