Old 06-05-2009   #26
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: Project: XP Stealth
Well It's 3060lbs and still missing the radiator and IC (pipes are in the car though). And it's only got about 4 gallons of gas in it. I'm guessing about 3130 will be the "final" current weight, with fuel, coolant, ic and door panels. Just makes me even more impressed with those select few that put the time and $ into getting these things under the 3000lb mark. I guess I'll have to see how it does. But I don't have the light rims on, I'll have to see what the difference in weight of the rim/tire combo is, the rims are ~10lbs lighter (each), but I'm not sure about the tires, 30mm wider.
On the plus side, light weight seats, and other more expensive parts are yet to be installed.
Edit: the race wheels will be -40lbs total.
I think it's time to ditch the crash bars maybe...
-21lbs for the front.
-36lbs rear.
-3lbs for one rear tow hook.
-~22lbs for the glass roof that I can take off at events... So close.
