Old 06-16-2009   #11
Re: Cobra Brakes on a 1G
Brake lines showed up today!
The end is the right diameter for the cobra banjo bolts. But there will need to be some tweaking of the banjo bolt required for it to work. With the bolt screwed down as far as it can go, it's still not tight down on the fitting. So I'll tap the bolt further, and that should hopefully take car of that. Might need to cut a little off the bottom if the bolt ends up being too long. I would have preferred it just fit correctly, but really is a fairly minor issue in the end.
Here's a pic showing what I'm talking about.
