Re: Dear twack and albert lea mike and all primo members please post!
The car was a mess. Nick Pretty much summed up what was wrong with the car.
Wires to sensors were broken
No idle stop switch
Tranny doesnt want to go into 1st
starter was bad
No gaskets on the oil return for the turbo
Missing metal timing covers
Knock sensor has no wires coming out of it
Vacuum lines capped off with screws
Rear wheel bearing is bad
Broken radiator neck
If I remember right the boost controller was hooked up wrong(not 100% sure I didnt fix it someone else did)
And one that I havent even told Nick about yet, Driver side ball joint needs replacing :/
Not to mension the tstat, and clutch Nick had already replaced.
Im sure there is more.
It sucks that you need to go through this. We are trying our best to help you out as much as possible.
1998 Spyder AWD
567hp
490tq
