Old 07-01-2009   #1
bob123131
97 gs-t 99k miles 3800
I'm sellin my 97 gs-t it has 99k miles, but im still driving it to prolly more like 101k by the time someone takes it. the psitures arnt the best, but will get more. All in the pictures is not installed, many parts were removed. Car runs like stock would be great for a build or just something nice to drive around in. Car has no emissions.
The good-All work done in 20k or less
oem rebuild with
Acl tri metal bearings
oem or topline piston rings-can;t member
polished crank
water pump
all timing componets except tensioner
New battery
Fresh oem head gasket and valve stem seals head was milled and checked by d and g motors
t-25 rebuild
Apexi n1 exhaust
apexi n1 downpise with wideband bung.
Fidenza light weight flywheel
act 2100 clutch- has like 3k miles
hard intake pipe with k and n filter
Possibly aftermarket black 17's depending on the price
still has ac
Only seen one minesota winter which was 06
Exhaust was used so has a little rust, otherwise car is clean even strut towers havent started rusting
Depending on price a j pipe, stock intake mani, extra set of altezza lights and some other little things may come with it.
The bad
pioneer Stereo acts up once and awhile and doesnt want to take a cd
Few small hail dents and one dent in fendor
Tires are pretty bald maybe 15 to 20 percent of tread left.
ID:	8922   Click image for larger version
