Old 07-07-2009   #19
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: No Reverse and bad noises...
For the shifting problem, you might want to look at replacing the in-car shifter bushings. My car did the same thing, replaced the bushings and problem solved. Because the bushings were just so worn out, it didn't allow the linkage to get into reverse position.
I already have all solid bushings in the shift linkage. I got it fixed though, thanks.
Don't worry about it Brandon, thanks for trying to help.
I'm going to try the oil pan again on Wed. Hopefully I can get it to seal all the way around.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
