Old 07-07-2009   #2
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: Need help with rim sizing
I bet you could get away with a 17x7.5 +30 offset easily. Maybe a 17x8.5 with a +35 or +40 offset but I don't know if it'd rub on the inside. I know those other guys get away with 17x8 Evo8 wheels and those are +37 offset I believe. Ideally, I would think 17x8.5 with a +40 offset would sit like the 17x8 +37 offset Evo wheels do on 1gs but stick out like 2mm which is nothing imo. (you might wanna check with 1g guys with Evo8 wheels to see how much inner clearance they have. If it was me, I'd get teh 17x8.5 + 30 and work with tire rubbing on the outside rather than inside(if there is any).
I've had 16x7.5 + 32 offset and the fronts stuck out about .5 inch so make that a 8.5" wheel and it'd stick out 1" on the fronts, the rears would probably be flush.
'04 Honda Ricer: stock
