Re: turbo question
[quote=blackrosenova400;308094]Well you probably do need a restrictor. How big of an oil drain do you have. Im running a 12 AN drain and i still think im cutting it close.[/quot
it's a 10an return line if I remember correctly. like I said my bullseye was fine on this oil feed and return setup. and I've only heard about having to run restrictors with bb turbos or if you've had your balance shafts removed.
given the amount of shaft play it already has I highly doubt a restrictor would do anything at this point
