Old 10-09-2009   #6
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Oh fun! Spun rod bearings!
Did you prime the engine before starting it?
I turned it by hand a few times, but did have quite a bit of lube in the oil pump housing. The funny thing is there was oil flow to the head, which is the last place the oil visits before returning to the pan.
I think I'll have to inspect the crank journals before installing the next crank. Live and learn I guess...
Asshanson, I've not yet verified if more than one spun. You can see oil coming out of 2 of the other rod bearings, but nothing on 4. If both 2 and 4 spun it really makes no sense because the oil galleries I believe are different to both bearings.
-Sebastian Vettel
