Old 01-06-2010   #13
Re: CBRD/Blouche BBK/BBK Lite turbo for Evo 8/9
There's a whole pile of results on this thing over the last year, figure I'd update this since it is still IMHO the bee's knees:
Crazy build:
4g64 Engine w/ Evo IX head..
Cosworth Cams
CBRD BBK Full Turbo @ 30psi
Buschur Double Pumper w/ 1200cc Injectors
E85 pump Fuel
Buschur Ported Intake Manifold & TB
Buschur Ported Exhaust Manifold
Stock 02 Housing
DC Sports Downpipe / Test Pipe
AWD Mini Battery Kit
AWD UICP & LICP
Stock fuel Rail
Stock Ignition
Stock Ecu w/ MAF Tuned By: Diiirk
http://forums.evolutionm.net/evo-dyn...bbk-turbo.html
Here are some results of the cbrd bbk in northern california. Some more info can be found @ http://evoempire.org/index.php/topic...d-bbk-results/
91 Octane:
PhoPoweR
2004 Evo 8 - BBK Full / 2.0 / 91 octane / 358whp/318wtq
Stevo8 2003 Evo 8 - BBK Full / 2.0 / 91 octane / 369whp/327wtq
Mods:
STEVO8 Spec ported BBK Full turbo
STEVO8 Spec ported Exhaust mani & Intake mani
Kelford 272's
Blox cam gears -2/-4
Forge WGA
Tomei BOV
AEM intake tube W/Perrin filter & vibrant maf adapter
ETS uicp
AMS licp
Perrin fmic
Milspec 65mm TB
AMS fuel rail
RC1200cc injectors
Titek V1 O2 housing
megan 3" DP
testpipe
3" catback with 16" resonator & muffler delete
Zeitronix Wideband
GM 3port boost solenoid using ECU-controlled boost
Stock motor
Stock MAF
Stock ECU
GST Motorsports custom dyno tune
Tephra V5 map switching (EcuFlash)
91 oct / E85 maps
E85 Ethanol:
Lqdchkn
2006 Evo 9 - BBK SPL / 2.3 / e85 ethanol / 476whp/464wtq
helloyellowevo
Mods:
BBK Full
HKS intake and induction pipe
HKS SSQV Bov
3" TBE no cat
Titek 02 housing
Generic FMIC
Nisei UICP
LICP
Walboro FP
RC 1200cc injectors
ARP headstuds
Brian Crower 280 cams
Adjustable Cam Gears
GST 2.3L stroker short block
Tephra Map switching on stock ECU
helloyellowevo 2003 Evo 8 - BBK Full / 2.3 / e85 ethanol / 415whp/440wtq
Stevo8
2003 Evo 8 - BBK Full / 2.0 / E85 ethanol / 445whp/394wtq
hansolo
2006 Evo 9 MR - BBK Full / 2.0 / E85 ethanol / 429whp/367wtq
Mods:
CBRD BBK Full turbo
Titek 02 housing
TBE 3"
MilSpec Hi-Flow Cat
HKS Mivec Cams
ARP HeadStuds
Springs and retainers
RC 1200cc injectors
Walbro fuel pump
Perrin FMIC
K&N cone filter (stock induction tube)
Injen Upper IC pipe
Lower IC pipe
MilSpec throttle body seals
Crushed OEM BOV
GM 3 port boost solenoid using ECU boost
TephraMods Map switching Rom
Stock ECU
Stock MAF
GST Motorsports tune
E85 and 91 octane tunes
PhoPoweR
2004 Evo 8 - BBK Full / 2.0 / E85 ethanol / 435whp/384wtq
Mods:
CBRD BBK Full Ported
Titek v2 02 Housing
Titek Down Pipe
RRE Rally Cat
Greddy Ti-C
FIC BlueMax 1250cc Injectors
Cosworth 272 M2's
Supertech Valvetrain
ARP Headstuds
Perrin FMIC
AMS LICP
AEM Short Ram Intake
Walboro Fuel Pump
Synchronic BOV
GM Boost Solenoid
Tephra Stock Ecu Map Switching
91 and E85 tunes
JDMevoBOOST
2006 Evo 9 MR - BBK Full / 2.0 / E85 ethanol / 437whp/370wtq
Mods:
Turbo & Exhaust
-CBRD BBK Full Ported
-MIL.Spec ported OEM exhaust mani
-Titek V1 02 housing
-Garage HRS DP
-Rallycat ( resonated test pipe)
-JIC Ti catback
Intake:
-Buschur cone on stock MAF no snorkel or box for these runs
-Speedsource LICP (AMS clone)
-ETS 3" IC
-Samco IC hoses
-MIL.SPEC 65mm T/B and I/M
-Hondata I/M spacer
-Synapse BOV
-Upgraded T/B seals
-GM 3 port boost solenoid
Valvetrain:
-Cosworth M2
-Supertech single springs and Ti retainers
-JAM non-tick lifters
-HKS Camgear
Fuel Delivery:
-FIC 1450cc
-single walboro
Spark:
-Denso IKH24
-Sun Hyperforce
Clutch:
-Exedy Twin Ceremetallic
-AMS clutch Lines
-MAP clutch fork stopper
E85 gizmos:
-GM Flex Fuel Sensor
-Zeitronix ZT2
-Zeitronix ECA (Measured 79% Ethanol for this tuning session)
Tephra V7 map switching and biggie maps (EcuFlash)
91 oct / E85 maps
