Thread: The Spazmobile
Old 02-17-2010   #31
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: The Spazmobile
Your EGR could cause an exhaust leak at the intake manifold and will make your car run funny under boost if not functioning properly.
It's directly under the center of the mani where the plug wires go, not from the side by the valve.
Regardless, I'm pretty sure the coil pack shouldn't be loud enough that I think I have an exhaust leak, and I know that's where the noise is coming from.
Scheides, you gonna be at OC tonight? If not, I'll probably just pick one up at O'Reilly after class.
Originally Posted by Trogdor
