Old 02-28-2010   #1
trunks11
trunks11's Avatar
1995 Eagle Talon TSI AWD
I do not want to sell but two kids to daycare doesn't work and I have two other dsms. So I will let it go for $3,900 to the right buyer.
1995 Eagle Talon TSI AWD manual
114,000 miles
Performance Mods:
-6 bolt with balance shaft removed installed by MAP summer 2004
- rebuilt eIII16g – probably less than 1,000 miles on it
-fmic
-synapse bov
-cop ignition setup
-1150 fic injectors
-aeromotive afpr
-6an fuel feed line
-dsm link
-gm maf and maft
-walbro 255
-fp race exhaust manifold
-megan ss o2 housing
-3 inch rre downpipe and highflow magnaflow cat
-3 inch apexi ws2 exhaust – sounds awesome and is quiet
-2 ½ inch intake pipe
-ACT 2600 clutch
-1g throttle body
-mishimoto radiator
-permacool fans
-external oil cooler with ss lines
-evo 10% taller 5th gear
Other Mods:
-all four seats heated
-proper two catch can setup with pcv and check valve
-aem wideband
-glowshift oil pressure gauge
-glowshift
boost gauge
-white faced stock gauges
-remote start – clutch safety switch disabled
-blacked out tails
-projector headlights
-2gb eclipse side skirts
-some sort of body kit front fender I’m told is rare that I actually don’t mind
Misc:
-new rims and tires this year – less than 1,000 miles on them
-just replaced driver lower control arm – ball joint went out
-new heater core this winter and hoses
The bad:
-the paint job is not great
-someone tried to bondo the back bumper into the body and its cracking
-having random starting issues - I'll be driving it to figure out problem - will update
-interior fan doesn't blow the best - maybe crap in the system since car sat a while
-car suffers from phantom knock which is currently shut off with dsm link
-interior painted and is dirty / peeling a little
The good:
-car has no rust except surface rust on driveshaft. I drove it a little this winter which is the first snow I think it's seen - has coating too
-quietest 3 inch exhaust I've ever heard
-leather is in good shape
I'm sure I am forgetting some things.. I've spent a lot of time on the car and am sad to see it go. I want to see it go to a good home.
ID:	9828   Click image for larger version
ID:	9829   Click image for larger version
ID:	9831   Click image for larger version
ID:	9832   Click image for larger version
