Old 03-05-2010   #36
Re: What are DSM people running for tranny fluid these days?
I use redline. I guess Shep also uses it. So, I use it in his tranny. a mix of mt-90, MTL, and the pink heavy shockproof oil..used to use the lightweight stuff. Only reason I switched was cuz MAP was outta the blue shtuff last year.
-A. Swift
Do not put in to much Heavy or you won't beable to shift unless your transmissoin is very very warm. The stealth saw straight lightweight.
Originally Posted by CarPsyco84 View Post
If you wanna wreck diffs, use GM Syncromesh, otherwise if you want actual gear oil redline from map seems to be the cheapest option.
I've had horrible luck with Syncromesh and dsm transmissions. Better luck using the valvoline GL-4 stuff you could get at Napa when redline isn't available.
