Old 03-13-2010   #14
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: recurring brake rotor problem...
I am not the best brake specialist in the world, but I am probably one of the most experienced here in said field.
when we stocked rotors, we threw them as frizbees, and dropped many, "
WTF!?
Point back to the cleaning of your hubs to see if that is causing the issue.
Also take your rotors in to have them turned, That will tell you for SURE if your rotor is warped or not. O'reilly does this service for you. if they aren't turnable they will tell you and not charge you. or just ask them to see if they are turnabout to begin with
