Thread
91 Galant VR4
03-26-2010
264
Tire Toss Champion!
12 Babes of Christmas Champion!
Drag Race Champion!
Drifting Champion!
Street Racer Champion!
Duck Hunter Champion!
3D Championship Golf Champion!
Drives: a moon taxi
Re: 91 Galant VR4
I now have the 4 hood pins mounted, then I just set the height when I have a hood to install. And the hood can be removed for easy work or can be pulled off with the front clip for bigger jobs.
I boxed in the upper frame rail to the unibody structure, this will help make the front end as strong as possible. Just a little more clean up and a few more welds, then its onto painting before the motor goes back in for finish assembly.
This strip of aluminum replaces the 2lb stock blob of metal, and this does the same job but is a 1/4 of the weight. This is the rear subframe front mount to the body.
The rear bumber cover is back on, I have some tabs on the top underside lip, then the plate in the middle that holds the bottom up. Now just a few more rivits and brackets in the wheel well area and the back of the car is done minus the rear window.
It is getting closer, we will be painting this weekend, then build the dash and start to lay out the wiring.
View Public Profile
Send a private message to Pushit2.0
Find More Posts by Pushit2.0
