Old 04-04-2010   #22
Re: Wiring my fans. I'm a n00b
That is the basic idea, again the only issue would be having a switched 12v source to trigger the relay (pin 85 in your diagram) unless you wanted the fans to run with out the ignition on. And your switch would complete the ground circuit for the fan relay and they would turn on no matter what the thermal switch was doing so a simple 2 pin switch would work, or if you get a lighted switch that would be a 3 pin unit.
