Old 05-17-2010   #11
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: 2004 Volvo S60R 66,500 miles 6 speed manual
Description S60 R
2.5 Liter, 5-Cylinder, Continously Variable Valve Timing DOHC, Turbo with Twin Intercoolers
Configuration Transverse
Displacement (cu.-in.) 2,521
Compression Ratio 8.5:1
Maximum Boost Pressure 1.0 bar
Horsepower (SAE net) 300 @ 5,500 rpm
Torque (ft. / lbs. SAE net) (6-speed close-ratio manual transmission) 295 @ 1,950-5,250 rpm
Max Engine Speed 6,500 rpm
Fuel, Rec. Octane Premium
Description S60 R
Anti-Lock Braking System with EBD and EBA
4-Piston Brembro Brakes with Aluminum Calipers
Disc Diameter (Front/Rear) 13 / 13 in
Wheelbase 107 in.
Height 55.0 in.
Length 181.3 in
Width 71.0 in.
Front Track 61.3 in.
Rear Track 60.7 in.
Towing Capacity 3,300 lbs.
Cargo Capacity (Rear Seat Up / Folded) -
Fuel Tank Capacity 18.5 U.S. Gallons
Trunk Capacity 13.9 cu.ft.
Curb Weight 3,571 lbs.
Weight Distribution, Front / Rear 55 / 45%
8" x 18" - "Pegusus" 5-Spoke Alloy Wheels with 235 / 40ZR-18 Tires, Y-Speed Rated
Suspension Front: MacPherson Struts with Asymmetrically Mounted Coil Springs, Electonically Controlled Hydraulic Shocks, 23.5 mm Stabalizer Bar
Suspension Rear: Multilink Independent Rear Suspension with Coil Springs, Electronically Controlled Hydraulic Shocks, 20 mm Stabalizer Bar
Six-Speed Close-Ratio Manual STD
First Gear 3.38 : 1
Second Gear 2.05 : 1
Third Gear 1.43 : 1
Fourth Gear 1.09 : 1
Fifth Gear 0.87 : 1
Sixth Gear 0.70 : 1
Final - Drive Ratio 3.77 : 1
Electroincally controlled all-wheel-drive
Four-C (Continuously Controlled Chassis Concept) System with Driver-Selectable Settings: Comfort, Sport, Advanced Sport
Top Speed (Electronically Controlled) 155 mph
Manual Acceleration (0-60 mph) estimated 5.4 sec.
Stopping Distance (from 62 mph) 118 ft.
Manual Trans City 18
Manual Trans Highway 25
-Colin
