Old 06-08-2010   #59
Re: Modern Automotive Performance
Goodhart,
How did you check that only the front wheels where moving..... Because i was just out in my garage, currently my car has only the front wheels up in the air. and the car is in 1st gear, The front tires will rotate. Granted one wheel is going one direction and the other going the opposite direction. Which is normal for our cars. Im really hoping this wasnt the way you checked that only the front tires were rotating.
Did you put the car in the air on all four jackstands and put the car in gear while running? Did you put it on an AWD Dyno? Did you do a smokey burnout? Were you sure the Tcase wasnt messed up?
A little description of how you came to the conclusion that the tranny was messed would be helpful in this situation.
tpunx99GSX is offline
