Thread: Evo X upgrades
Old 08-31-2010   #1366
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Do you mean RPM boost control?
I'm not an ECU geek, that's just what Tephra calls it. By default the X uses load targets and you can't actually tell it to hit a particular psi target. Every dyno you run the car on will hit a different peak boost because it loads the car differently.
The best analogy I've heard is that it will behave like an ECU-adjusted MBC afterward.
http://www.evoxforums.com/forums/sho...893#post522893
