Thread: Proj. Talon MR
Old 10-01-2010   #16
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
Re: Proj. Talon MR
It's back together, drives straight, rides nice (as good as K-Sports can get). Sears pulled the frame straight, Jeff aligned it, but I still need to replace the lower control arm as it maybe bent a little. No worry as I was planning on replacing the control arm bushing rubber w/ poly. I took off the Evo MR rims and swapped in the daily driver 18s / all seasons. No need to be burning up the Evo Yoko rubber on casual street driving.
Now I can start modding it. Won't be driving it during the winter months so I'll be able to work on it in the storage garage. So far planning on doing:
- Canadian seat belt conversion (hate the chokers + weight reduc.)
- Headliner started to come down quite a bit, so I'll pull the headliner out and redo it w/ black alcantara in an attempt to remove some of the porno-red from the interior.
- Retrofit the 2g crash beams in the front and the back. (quite a bit of weight reduc.)
- Replace the battery with gel type and relocate it to the trunk.
- Modify the washer reservoir in the trunk to work as the washer for the front wipers (like how the 2gs have it), and remove the front reservoir completely.
- Modify the mid 90s caddy plastic undertray that I got, to fit the front bumper.
There is a few more things, like actual performance mods but those I'm planning in spring time, e85, eIII 16g...
ID:	10759   Click image for larger version
