Thread: evap canister
Old 10-02-2010   #5
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
Re: evap canister
Remove everything EGR related, lines and solenoids, put a block off plate over the EGR port and let er' buck. You'll have to cap the lines by the gas tank and on the intake manifold and put a breather filter in place of the PCV valve. Follow the vac diagram
if you want the check engine light to go away you'll have to get a scanner to disable the EGR system so the computer ecu doesn't even look for it on start-up
I believe your engine will run cooler with EGR deleted and what not and you'll need 1 degree cooler plugs too, but this is if you delete the entire system.
But yea, vfaq.com fuckin' rocks. Check it out.
