Old 11-09-2010   #1
Re: Borg Warner Turbos
that's 67mm exducer. They name their turbos different than PTE. PTE uses comp inducer and turbine exducer (i.e. 6265)
BW uses comp exducer and turbine inducer (i.e. 83-74)
So the 67mm turbo you are looking at, would be more commonly referred to as a 53mm turbo (that's the inducer).
The 83-74 (a 62mm turbo) they rated at 79lb/min!!!
And the real 67mm turbo (91-80) they've rated at 94lb/min.
