Thread: Project Lex
Old 05-13-2011   #15
Re: Project Lex
This year is 350-400hp. Just going to run WG boost levels to get used to the car, get kinks worked out, and also the current drivetrain can't handle much more.
And more updates
PP torqued to 14lb/ft. Tranny is back in, woo woo. Driveshaft and all that stuff is back in. Thanks for letting me borrow the tranny jack Aaron. I don't think I coulda done this job without it.
SO with that being done, what's next? Manifold. Thanks again to Andy at Elite for chopping off the old WG flange and tacking my new one in place.
Test fitting everything up. Brand new exh. mani gaskets Going to chop the end off the comp housing and get a 90* welded on that. Mo lemme know when you got your welder all setup!!
Onto the pics!
Collector. Seen better, but seen worse. It'll do just fine for me
Exh. Housing on, and downpipe halfass installed just for me to see how it lines up.
More test fitting:
Extended Tip Son!!
ID:	11650   Click image for larger version
ID:	11651   Click image for larger version
ID:	11653   Click image for larger version
ID:	11654   Click image for larger version
ID:	11656   Click image for larger version
ID:	11657   Click image for larger version
