Old 10-03-2011   #11
This is why you need a wideband. Timing looks good but the car is knocking 2-3 counts across the board. Who knows if its lean or rich or what. Check all your couplers. Check for leaks. Check your oil, check your coolant.
Double check everything.
Boost leak test and compression test, stat.
Oh, and if its running like shit, don't rev it to 8000 :P ...you know something is wrong by the time you get to 4500rpm, don't push it man!
