Old 10-24-2011   #10
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: Opinions on a Mini Cooper S?
Shawn -
The wife DD's an 02 MCS with a 15% pulley and CAI. (I'd recommend those two mods, woke it up quite considerably, and still drives like a stock car).
We've had it for about 2 years now. It's been a very good car for us.
Here is my thoughts. The car handles awesome. Moves pretty good. S/C wine is a bit addicting!
The interior isn't great but I have definitly seen worse. I think peoples biggest problem with the interior would be the speedo being in the center. Ours has navigation, so it moves the speedo next to the tach on the steering column, so its a bit more normal.
3 adults can fit decently comfortably in it. Forth is tricky if the driver is taller than about 5'8". inside with 2 adults it imo doesn't feel cramped.
The Traction control sucks, basically gets turned off when driving in the winter. We have a set of General Artimax Artics on it for the winter and it does really well at getting through the snow.
Cruise control is good, the mpg is good we average a little over 30 DD, which involves some stop and go.
The only issue we've had is it threw a code and went into limp mode a couple times, but found a wire that had warn threw the insulation, fixed that and it hasn't done it sense. We also had the cable that hooks up to the door handle on the drivers side come out of its clip inside the door. Kind of a pita, but once you know how to fix it, its pretty simple, like a 20min fix.
Craig is another person to ask he has also owned one, and from what I know still wants one.
www.northamericanmotoring is the national forum for minis. Also check out this thread about minis common problems and what to look for when buying them.
http://www.northamericanmotoring.com...nce-guide.html
That car seems pretty cheap, check out the carfax, and such. Most likely becuase of miles. Looks like a fun Winter DD. GL! LMK if you have any questions or want to look at it or something.
