Old 06-14-2012   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
So, battling fuel pressure problems right now. My AEM is adjusted for max fuel pressure and it won't go above 42ish at idle.
So as I believe Shane suspected, the car appears to be bleeding fuel back through the second pump. Doing some testing now, but might be getting a check valve for the second pump soon.
Need to bump fuel pressure so we can reduce load as I was hitting 330load and boost cut (319 load) on pump gas at like 24psi.
So we are making it so the load is hopefully 270ish around there by changing around a lot of stuff. (injector scaling, MAF/MAp tables etc)
Not going to lie, I doubt I am going to PG. Especially since work is really crazy. I am kinda bummed but frankly I don't want to go until the car is working fully. I will head out to RF or BIR at a test and tune day when its done if I don't make it.
Still going to try and make it but not looking good now.
