Old 08-17-2012   #10
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Well same issue. Not sure what the culprit is now.
you could try wireing it up kiggly mod or 2 switch style to eliminate valve body/solinoid issue. I'm sure its the first thing you did but I would also double check all the plugs and harness' and that the shift linkage is adjusted properly. Theh 2 plugs on top of the trans would be easy to miss or not get pluged in all the way.
11.35 @ 120mph
