Old 10-01-2012   #12
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: What's a good price of carpet installed?
Yeap I do steps.
To speedfreak.
For carpet you could pay $9-$50/yard (average residential $15-18)
Install is from $4-6/yard
Take up is around $1.25/yard
Pad is bought in 30 yard rolls $100-$150 a roll
Carpet and pad price vary since there are different qualitys and styles.
Your bedroom would probably fall in to the minimum carpet charge which can be $125-$175 depending on if you find the labor or the shop you buy the carpet from does.
Carpet on step is a labor charge of $7 a step but also if this is all you have it would fall most likely under min. charge.
The reason for the min. charge is because the shitty mpg we get in our vans and usually only make $75 on a min. charge job.
Your bedroom is 18yrds
So on average you should pay this
$450-$550 for carpet pad and install
Hope this helps.
