Thread: Project Lex
Old 03-15-2013   #17
Re: Project Lex
Got a little done today. Big thanks to Joel for picking up a -10AN fitting from MAP from my drain line. I decided to try Earl's youtube method of cutting the SS Braided Line (using a chisel). Worked like a charm!
So got the new drain line done and installed. Bolted the turbo down but need to find some safety wire to wire the bolts up. Got the radiator and shroud installed. Found I broke off one of the soldered wires (must have happened while pulling the engine) so re-soldered that. Ran the harness back into the inside of the car. Continued just hooking things up as I came across them.
Couple questions, in case by some random chance anyone here knows.
Where does this wire go? Obviously it hooks to the negative of the batter, but no idea where the other end goes.
Also anybody know what this is supposed to plug into? I have it labeled as intake manifold, but I don't see anywhere for it to go. Maybe it went to the EGR stuff I removed?
ID:	13413   Click image for larger version
ID:	13414   Click image for larger version
ID:	13416   Click image for larger version
ID:	13417   Click image for larger version
ID:	13419   Click image for larger version
ID:	13420   Click image for larger version
