Old 03-23-2013   #11
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: Project Slowbaru
Well WTF...
I just heard that my setup may not work due to the difference in the cam gears on the EJ25D heads and what the WRX ECU needs. Apparently I can't swap WRX gears over either.
Plus I have to figure out my TGV situation. I don't know if Opensource will allow me to disable the CEL associated with removing your TGV's that throws the ECU in limp mode.
Back to the drawing board!
So far from what I am finding on NASIOC is that open source will disable the TGV codes. Which is good. A thread I found had a screen shot of Rom Raider and there was a spot to turn off the cel's.
http://forums.nasioc.com/forums/show....php?t=1873118
