Old 04-25-2013   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I haven't seen the SD stuff for the X, but the VE has got to be way out of whack around 4000rpm. Keep going, don't blow it up. You'll get it.
zero knock through any run i have logged so far, its running very strong so far. Just shitty down low. I agree, i think the VE (MAP tables) and maybe fuel calibration table need adjusting down there as the new turbo just flows so much more, the car felt pretty beastly with wastegate pressure, liking it so far.
Nice, going for some power I see.
Maybe
Full boost at 4100 isn't bad at all. Looks promising and can't wait to see it running good!
I think it will potentially be even better with mivec and proper fueling etc. I wasn't able to really get into down low as the fueling is so off down there. Once I get fueling figured out, the car should spool by 4kish I think.
