Old 06-09-2013   #1
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
.020 9:1cr JE pistons and stock E8 rods
Alright, I have some JE pistons I just pressed off some modded 6 bolt rods that I don't need, they are the 22mm wrist pin and are 85.5mm or .020 over. They have some scuffing starting on them but if you cleaned them up a little they would be fine, comes with JE wristpins but no wire locks as they were pressed on. I also have some stock Evo 8 rods, they are the strongest of the oem 7 bolt rods, I just needed the pistons off them. $200 takes all of it. Text 6512786390 for fastest response
punxnotdead185 is offline   Reply With Quote
