Old 07-06-2013   #1
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
Custom HE351CW, ported, billet wheel, etc
I have a modified HE351CW I was going to use on my Mirage but just sticking with the 20g for now. It has a custom slim nose billet HX40 compressor wheel, fresh rebuild and balanced with the new wheel, I shaved the excess fittings off the comp cover and had them all welded shut, the turbine housing has had the big 4"+ vband flange cut off and the wg has a plate welded over it and a 2.5" vband flange welded on, housing was all preheated before welding and has been heat cycled once to make sure it wouldn't crack, also the turbine housing is professionally ported. People have done a hair over 650whp on these stock with the cast titanium wheel so with the lighter slim nose billet wheel it should do a little better both power and spool time wise, plus the porting will help with flow and spool time also. This has a open T3 9cm2 turbine housing and a slightly smaller turbine wheel than the HX35 so it should out spool it by a significant amount while laying down HX40 pro power numbers. If interested or have any questions PM me. Asking $700 because that's about what I have into it and plus my time porting and welding but open to offers. Currently missing the vband holding the chra to the turbine housing but I have one on order right now and will be fixed before being sold, clamp should be here any day.
ID:	13782   Click image for larger version
ID:	13783   Click image for larger version
ID:	13785   Click image for larger version
ID:	13786   Click image for larger version
punxnotdead185 is offline   Reply With Quote
