Old 07-16-2014   #34
blackrosenova400
blackrosenova400's Avatar
Re: Shari's 2009 Raliart
Here is where Mitsubishi neglected to install a 2$ o-ring to properly seal water/rust contamination.
Here you can see the teeth heavily worn from rust on the t-case.
Here there is a pile of powered rust. There is actually more than what the picture is showing.
There is alot more damage I cant get a good shot of at the moment. Specifically completlely missing teeth/splines.
Its all stripped out and the repair probably will require a new t-case and new front differnetial in the transmission.
20g Mafia
