Old 03-21-2016   #202
Re: Goodhart's budget beater 1g
Ok, this one has me overthinking a bit.
The stock coolant return pipe won't work for my setup and it's too close to the turbine housing for me to feel comfortable using rubber so I'm going to do a braided line. I plan on doing a banjo to -6AN to replicate the stock piece and loop it behind to the water pipe.
Anyways, I need a fitting that will work with the water pipe flare. So I'm looking for -6AN to M16x1.5, with the M16 end having a flare like the stock piece so it'll seal.
Looking at
THIS part here, hoping it'll work. Thoughts?
TLDR; Need the correct fitting to go into the water pipe and connect to a 6AN on the other end with the correct flare to seal in the water pipe. (I'm pretty sure they are both 37° flares)
It will be replacing this:
