Old 06-22-2016   #11
Almost finished with the Mishimoto 25 Row universal kit install.
How to run the lines are the only issue left (fingers crossed I haven't tried to put the bumper back on yet though.
Currently the lines running/mounted behind the fmic I ran into an issue where they weren't long enough avoid the i/c piping (I couldn't rotate the fitting enough to clear)
Which was a huge let down as I thought I was all done.
Buy anyways here's the progress so far. If I can't get it to work on this location. I also fabricated brackets to mount the cooler between the FMIC and a/c condensor.
The only thing so far I had to change about the kit is I had to change out the "straight fittings, for a 2nd set of 90 degree fittings", the forward facing oil filter housing makes it so you need them.
ID:	15968   Click image for larger version
ID:	15969   Click image for larger version
