Old 10-10-2016   #1
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
1999 Corvette Fixed Roof Coupe, 99k, 6-speed, Heads, Cam, Suspension
Up for sale is my 1999 FRC (fixed roof coupe) C5 Corvette, Black exterior, with mod red interior swapped out of a z06. I built the car to get into doing track days. When I purchased the car from a friend it was in completely stock form, ls1 6-speed. All mods have been done to the car less than 1,500 miles ago. The car currently has 99,xxx miles on it with all mods done over this last winter to also include: new ignition switch, starter solenoid, spark plugs, plug wires, 02 sensors, belts, pulleys, tensioners, alternator, all fluids, and tires. The car's modification lists are in the images.
With my intent for the car to be used for track days I went through the whole car and replaced all of the common wear items to ensure reliability. The car runs like a top and previously made 412 whp / 387 wtq on the dyno this spring with a very rich and overly conservative timing. With the car leaned out now and running more timing it should be well north of 425 whp.
I will be completely up front and tell you that this is not your grandpa's garage queen corvette; there are paint chips and various minor imperfections around the car. The A/C currently isn't charged but everything is in there and works with all new o-rings installed throughout the whole system over the winter, I also have a new dryer to go in the car when it is finally re charged.
I did all of the work myself with a great attention to detail through out the whole build and only using high quality parts. I tuned the car myself where I spent many hours perfecting it and working on the smaller things that are often overlooked in a tune. I only have been able to do four auto-x events and a HPDE with the car so far this summer otherwise it generally sits in the garage.
$15,000
ID:	16179   Click image for larger version
ID:	16180   Click image for larger version
ID:	16182   Click image for larger version
ID:	16183   Click image for larger version
Jungy is offline   Reply With Quote
